95gstnj
- 60
- 1
- Feb 11, 2004
howell,
New Jersey
Hey everyone, it seems like my spark is getting blown out cruising on the highway at above 3000 rpms. i'll be cruising at a constant speed, not under load at all, and it feels like my spark will get blown out in one or more cylinders. if I catch it in time and let off the gas completely within half a second, it goes back to normal, if not it will stay in that state even if i do let off the gas, then get back on it. then, i need to let the car just idle for a few seconds, then it goes back to normal. it is happening on different cylinders because sometimes when it happens my egt gauge drops to almost zero, and other times, it stays normal. it does this sometimes under boost
i've tried numerous sets of wires,
brand new sets of bpr6es&7es gapped to .028
swapped my coilpack
NO LOGGER
NO BOOST LEAKS
stock 450's, no fuel management
running 10 psi
this is on a 98gsx 6bolt
any help is appreciated
thanks
swapped my coilpack
NO LOGGER
NO BOOST LEAKS
running 10 psi
thanks
