SilverJester
- 95
- 1
- Aug 31, 2002
Ok so my car died on me the other night just as I was getting on the highway (no symptoms, it just suddenly shut off). But for the past 2-3 months the plastic plug the goes to the ignitor has been vibrating loose (I think the plastic warped a just enought to were it doesn't clip into place). It only vibrates if I am racing, daily driving it stays in place....but when it does come loose the car shuts off. Now my first thought was that maybe disconnecting like that while the car was running might have damaged the ignitor itself...so I replaced it, and the car still doesn't run. Next I tried changing he coils and ignition wires....but I still have no spark.
At this point my only thought is that either the Crank or Cam angle sensors have to be replaced (probably resulting from the ignitor wire commig unplugged while the car was running). This is a 95 4g63t, and because of that, it makes chaning the Cam Angle Sensor a bi***, because I have to take off the timing belt. Is there a way to test these 2 sensors before removing the timing belt and/or is there anything else that could keep my car from getting any spark? thanks for any input.
It must have hit the crank angle sensor causing the bolt the vibrate loose and the car to die.
