Boost leak ?
ALP584
96
Sep 9, 2003
I recently purchased a sbr mbc. I installed it correctly tied in all connections with zip ties to make sure it doesnt leak , well when I was done with the installation , I took it for a spin and no matter how I set the mbc it boosts past 17 psi almost to 20psi and it doesnt feel like it pulls hard more like the power is going away car is a 91 tsi awd 5spd with 77,000 miles all maintanence done , has a boost gauge and mbc. Im doing a boost leak test I just wanted to see if a boost leak would cause this since I never had this problem on my fwd dsm.
Thanx
You might be getting boost creep, as in slowly moving up the boost pressure...and not having a lack of boost (boost leak). The creep would build up and seem like a loss of power like a boost leak.
Unless the car was also boosting as described before the install of the MBC it's clearly not boost creep.
I expect one of two things are going on. The MBC was installed the wrong way or it's defective. You can test the MBC by connecting an adjustable air source to the input and raising the pressure until the MBC valve opens. That pressure is about what the MBC will hold your boost at.
Connecting the pressure source (the nipple on the j-pipe) directly to the wastegate will show you if the problem is not in the MBC.
Steve
Well I did a boost leak test at the turbo , and also at the throttle body. Did not find any boost leaks other than the blow off valve leaking at 16-17 psi which I think is as good as it gets on a 1g. Also the mbc does have a little hole in one of its inlets which lets air out but
that is what its suppossed to be I plugged that hole up when I did the boost leak test . After all was done I hooked everything back up just to have the same problem again, and the car before the install boosted around 11 psi stock. The boost slowly goes up and creeps to 22 psi no matter how I set the boost controller.
:rolleyes: any input is appreciated
Most MBC's have a bleeder hole in them, so don't worry about that. Do you have the MBC hooked up properly? Bottom nipple should go to your boost source, middle/side nipple goes to wastegate.
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
