Livid
- 287
- 3
- Feb 8, 2005
Granville,
New York
The other day I noticed that I had a boost leak. The vacuum line coming out from the TB towards the Selenoid on the right/front of the head ( I'm not sure exactly what it's called) was blown apart. So i plugged it temporarily which worked fine. After which I reconnected it to the selenoid. Now everytime I try to start my car it tries to crank over but won't go unless I give it gas and keep the ignition turned for 10 or so seconds. I'm not sure if the vacuum line and the problems are related but it happened around the same time. Not sure how to fix this or what it could be?
anyways post a pic that would probably help a bit
