just installed a s-afc in my 97 gs-t and check engine light came on :(
seahorse
35
Jul 29, 2005
yonkers, New York
hey guys i just installed a s-afc in my 97 gs-t and the check engine light came on :( . know i installed it right car runs perfect any clue ...:confused:
yep anything is zero...i also installed a 3" intake pipe ..so no more valve cover breather lines goin in to the intake pipe and the other line is just opened to atmosphere..cause my 3" intake pipe doesnt have fittings to put these lines in ..it just has the bov return and that is hooked up ...
hey now i dont know if my s-afc is hook up right cause ......if i change the karman to hot wire or any other setting it still runns the same ...i had this same afc in my first gen when i would change karman to hot wire or any other settings it would run like crap ..
hey i fixed the problem turns out the pink and orange wires on the afc was hook up where the grey does
