S_Ranger
Banned Member
- 761
- 6
- Aug 30, 2004
ca,
Central America
My acc. cable came loose one time after a quick race. The 2 nuts holding it in place to the bracket were loose. I tightened it back up then took it home. No problems. I was bored so I did the fuel pump re-wire mod. Everything is connected where it should be but now my idle fluctuates between 1-2000k. At a stop it will be normal, it just does this every now and then. I don't see no boost leaks but I hear a hissing from the tb so maybe tiem for a new gasket but other than that what would be the cause for this? And instructions on how to fix it please.
