external wastegate
GSXspeeddemon
88
Sep 20, 2005
Austin, Texas
i got an offer for an external wastegate that i couldnt refuse. So know i am wondering about putting it on. I currently have a big 16g turbo internally gated and i was wondering if there is anyway to make it externally gated or can i just put the on the external, with the internal or what? Any imput appreciated. Thank You.
-gsxspeeddemon
You have a couple of choices. You have to eliminate the internal no matter what though. You can weld the flapper door shut on the internal and put the external on the first runner of the exhaust manifold or if you want it on the o2 you can remove the flapper and take a dremel to make the hole a little bigger. Hope this helps. :thumb:
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
