Amorphous
- Oct 21, 2005
Galloway,
New Jersey
I recently had an idle problem with my car. I checked my ISC and it was busted. I replaced it for a new one. I did a boost test on my turbo and didnt find any leaks. When I did this I found loads of oil in my intake. I cleaned it out and put a filter on my PCV line to the intake. I cleaned all the oil out of my MAF and car was fine and the idle surge was gone. Accept for 2k rpm idle. I knew it was my BISS and was too lazy to adjust it.
I finally got around to adjusting it today. I adjusted the BISS to 900 rpm (far down as it could go), and I turned it off. Then disconnected the grounds and started her up again. It now idles at 800-900 and surges again K. I yanked out my intake tube and looked inside to see if there was any oil or if my MAF was covered with oil again, and it wasnt. There was just a small amount at the bottom (I drove it for 2-3 days before I put the filter on it). I began probing the MAF as my Haynes manual instructs because I just suspect that the MAF is just junk. My Air Intake Temperature sensor read 3.6k ohms (around 40 degrees outside). I made a small graph it is slightly off, but not terribly. Then I checked the harness side of it (pin 2 for AIT and pin 3 for barometric sensor) and found a very small voltage from both. Pin 3 shouldve been 12v right from the battery. I got 0.2v
. Pin 2 was the same voltage. According to Haynes
its not supposed to be. If the MAF were not getting power, would the ECM be able to do what ever it wants? Idle badly and produce a rich condition? My car still produces a lot of Carbon Monoxide. I can smell it K. Help would be appreciated.
Don't know why I barely got any voltage before. Back to the drawing board. FAIV maybe?
Twas fun though. Can't boost for shit either. 4k rpm and it bucks like hell. Guess at first light I'll readjust the BISS again.
, no ####ing wonder." Big boost leak there
