wells move in nutral
sage
Oct 16, 2005
pueblo, Colorado
i had my car on jack stands and in newtral and the front wells trun u can stop them bye hand but they start to move agian when they move the idle jumps need help
I couldnt understand one thing that said. but if your saying your car is running while its on jackstands and the wheels move? thats normal dont worry about it.
sorry about my splleing r u sure about that cuse when u stop them the car runs fine but when they move the idel jumps up and down and the car moves on the grownd and not on a hill
Clean up your posts... proper spelling and grammar are necessary to properly convey your question.
As for the wheels, it's fine if they move when raised above the ground and in neutral. There is probably little correlation to your rough idle. Look for other possible culprits such as vacuum leaks, bad injectors, or bad plugs.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
