kmartsTsi
- Dec 24, 2005
Hubertus,
Wisconsin
Ok. Heres the deal. About 2 months ago, my car would not start. It turned out to be the ecm was fried, so i sent it out and had it re-built. I got it back, and the car runs fine, but now the only gauge that works is the spedo. I have pulled the whole gauge cluster out, and all the leads to the gauges work. I also checked the fuses and they are fine. I then sent the ecm back to see if that was the problem, but it worked in the companys test car. They told me that the problem could be a switch, that goes from the fuses to the switch which is for the gauges. I was wondering if anyone has had this problem, or if they know of a part # for the gauges. Thanks.
