97GsXfreak
- 137
- 1
- Nov 15, 2004
Berkeley Heights,
New Jersey
I just got my car back from getting a 6bolt in for my blown 7bolt that spun a rod. I got the car boost leak tested and then dyno'd after the swap was done(it was a used motor). I got 275whp at 16psi of boost and i didn't know why they would tune it at 16psi because last time i got it tuned they tuned it to 21psi so w.e i was driving home and when i hit 16psi at 6000rpm's the car felt like it hit fuel cut i jerked hard and then kept accelerating. I turned up the boost and it does this cutting out even more offen and i don't understand what the problem could be. I have 660's and a 255lph pump with a regulator and a td05h 20g. I could only call the shop because i had to go back to college but they said my alternator was crapping out so i installed a new one and same problem. I also noticed that my s-afc corrections were very weird for having 660's...2krpms the correction was like -2% and it gradually got less to 6krpms at -8% but i thought the corrections would be much lower. They supposedly checked for boost leaks and thats the only thing i could think of. Any ideas?
