logging diffaculty's
compression
1,433
12
Dec 9, 2004
vero beach, Florida
ok, ive searched , and did not find my answer so i am starting a new thread, let me start by saying im logging with mmcd and i have a 1.8 turbo, 1st off, how do i get my log onto my computer for easier posting?
i have 450cc injectors, no fuel tuning or correctioning
short 3rd gear pull
tps rpm 02v tima injd
99.6 4593 .62 49 50.7
99.6 4625 .60 31 50.7
99.6 4781 .66 32 53.1
99.6 4906 .74 32 53.1
99.6 5062 .70 32 54.6
what do you think? i am a noob i guess you could say with this , seeing as my cable just came in today remember i have a 1.8 turbo, this is at 6psi with boostleaks and untuned
You should be able to "hotsync" or something to your PC. That's how pocketloggers work.
To get a decent log, you've got to get from 3k-7k.
Your o2's and timing don't make much sense, but I suppose it could have something to do with the 1.8
Do another log and drop the IDC off the list.
Getting the log off the Palm and onto the PC in a form you can do something useful with is one of the issues with MMCd. There is another program called mmcdtools that does it.
If you running 450cc injectors on a 1.8L what are you using for a ECU? If your using the 1.8L ECU than there is no point in logging until you get something to compensate for what would be huge injectors to that ECU.
Steve
1.8's redline at 6k and start bouncing at 6500 =$ yes stock 1.8 ecu, it runs decent, but the o2 , shouldnt it be a little higher?.65's is a little on the lean side right?
i have the stock injectors, should i put those in and log it? and if the ijdc doesnt go over 80 i should be ok right?, or i could get some injectors off of my 91 talon n/t (dont know cc)
TIME,........ COOL, ........FTRL, ...FTRM, ...FTRH, ......FTO2, ..... TPS , .... ........ERPM, ........INJP...
2005-10-27 11:46:06,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.51V,,,,72.94%,,,3187.50rpm,,11.26ms,38.00,,,,,,,,,,,
2005-10-27 11:46:06,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,3218.75rpm,,12.03ms,41.00,,,,,,,,,,,
2005-10-27 11:46:07,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,3281.25rpm,,12.54ms,43.00,,,,,,,,,,,
2005-10-27 11:46:07,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.62V,,,,100.00%,,,3343.75rpm,,12.80ms,45.00,,,,,,,,,,,
2005-10-27 11:46:07,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.62V,,,,100.00%,,,3406.25rpm,,12.80ms,46.00,,,,,,,,,,,
2005-10-27 11:46:07,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.62V,,,,100.00%,,,3500.00rpm,,13.06ms,48.00,,,,,,,,,,,
2005-10-27 11:46:08,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,3562.50rpm,,12.80ms,48.00,,,,,,,,,,,
2005-10-27 11:46:08,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.57V,,,,100.00%,,,3593.75rpm,,13.06ms,50.00,,,,,,,,,,,
2005-10-27 11:46:08,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.55V,,,,100.00%,,,3687.50rpm,,13.06ms,51.00,,,,,,,,,,,
2005-10-27 11:46:08,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.53V,,,,100.00%,,,3750.00rpm,,13.06ms,52.00,,,,,,,,,,,
2005-10-27 11:46:09,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.49V,,,,100.00%,,,3843.75rpm,,13.31ms,54.00,,,,,,,,,,,
2005-10-27 11:46:09,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.47V,,,,100.00%,,,3906.25rpm,,13.31ms,55.00,,,,,,,,,,,
2005-10-27 11:46:09,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.45V,,,,100.00%,,,3968.75rpm,,13.31ms,56.00,,,,,,,,,,,
2005-10-27 11:46:10,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.45V,,,,100.00%,,,4062.50rpm,,13.31ms,57.00,,,,,,,,,,,
2005-10-27 11:46:10,,,29.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.45V,,,,100.00%,,,4093.75rpm,,13.31ms,58.00,,,,,,,,,,,
2005-10-27 11:46:10,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.43V,,,,100.00%,,,4187.50rpm,,13.31ms,59.00,,,,,,,,,,,
2005-10-27 11:46:10,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.43V,,,,100.00%,,,4218.75rpm,,13.31ms,60.00,,,,,,,,,,,
2005-10-27 11:46:11,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.43V,,,,100.00%,,,4281.25rpm,,13.31ms,60.00,,,,,,,,,,,
2005-10-27 11:46:11,,,30.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.43V,,,,100.00%,,,4375.00rpm,,13.06ms,61.00,,,,,,,,,,,
2005-10-27 11:46:11,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.45V,,,,100.00%,,,4437.50rpm,,13.06ms,61.00,,,,,,,,,,,
2005-10-27 11:46:12,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.45V,,,,100.00%,,,4500.00rpm,,13.06ms,62.00,,,,,,,,,,,
2005-10-27 11:46:12,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.47V,,,,100.00%,,,4531.25rpm,,13.06ms,63.00,,,,,,,,,,,
2005-10-27 11:46:12,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.47V,,,,100.00%,,,4593.75rpm,,13.06ms,64.00,,,,,,,,,,,
2005-10-27 11:46:12,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.49V,,,,100.00%,,,4687.50rpm,,13.06ms,65.00,,,,,,,,,,,
2005-10-27 11:46:13,,,31.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.49V,,,,100.00%,,,4750.00rpm,,13.06ms,66.00,,,,,,,,,,,
2005-10-27 11:46:13,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.51V,,,,100.00%,,,4812.50rpm,,13.06ms,67.00,,,,,,,,,,,
2005-10-27 11:46:13,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.53V,,,,100.00%,,,4875.00rpm,,13.06ms,68.00,,,,,,,,,,,
2005-10-27 11:46:14,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.55V,,,,100.00%,,,4937.50rpm,,13.06ms,68.00,,,,,,,,,,,
2005-10-27 11:46:14,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.55V,,,,100.00%,,,4968.75rpm,,13.06ms,69.00,,,,,,,,,,,
2005-10-27 11:46:14,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,5062.50rpm,,12.80ms,69.00,,,,,,,,,,,
2005-10-27 11:46:14,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.58V,,,,100.00%,,,5093.75rpm,,12.80ms,69.00,,,,,,,,,,,
2005-10-27 11:46:15,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.58V,,,,100.00%,,,5125.00rpm,,12.80ms,70.00,,,,,,,,,,,
2005-10-27 11:46:15,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.58V,,,,100.00%,,,5187.50rpm,,12.54ms,69.00,,,,,,,,,,,
2005-10-27 11:46:15,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.58V,,,,100.00%,,,5218.75rpm,,12.54ms,69.00,,,,,,,,,,,
2005-10-27 11:46:15,,,32.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.58V,,,,100.00%,,,5281.25rpm,,12.54ms,70.00,,,,,,,,,,,
2005-10-27 11:46:16,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,5312.50rpm,,12.29ms,69.00,,,,,,,,,,,
2005-10-27 11:46:16,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.60V,,,,100.00%,,,5375.00rpm,,12.29ms,70.00,,,,,,,,,,,
2005-10-27 11:46:16,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.64V,,,,100.00%,,,5406.25rpm,,12.03ms,69.00,,,,,,,,,,,
2005-10-27 11:46:16,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.62V,,,,100.00%,,,5437.50rpm,,12.03ms,69.00,,,,,,,,,,,
2005-10-27 11:46:17,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.64V,,,,100.00%,,,5500.00rpm,,12.03ms,70.00,,,,,,,,,,,
2005-10-27 11:46:17,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.64V,,,,100.00%,,,5531.25rpm,,12.03ms,71.00,,,,,,,,,,,
2005-10-27 11:46:17,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.70V,,,,100.00%,,,5531.25rpm,,12.03ms,71.00,,,,,,,,,,,
2005-10-27 11:46:17,,,33.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.72V,,,,100.00%,,,5562.50rpm,,12.03ms,71.00,,,,,,,,,,,
2005-10-27 11:46:17,,,34.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.68V,,,,100.00%,,,5593.75rpm,,12.03ms,71.00,,,,,,,,,,,
2005-10-27 11:46:18,,,34.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.72V,,,,100.00%,,,5625.00rpm,,11.78ms,70.00,,,,,,,,,,,
2005-10-27 11:46:18,,,34.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.72V,,,,100.00%,,,5656.25rpm,,11.78ms,71.00,,,,,,,,,,,
2005-10-27 11:46:18,,,34.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.68V,,,,100.00%,,,5687.50rpm,,11.78ms,71.00,,,,,,,,,,,
2005-10-27 11:46:18,,,34.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.74V,,,,100.00%,,,5687.50rpm,,11.78ms,71.00,,,,,,,,,,,
2005-10-27 11:46:19,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.70V,,,,100.00%,,,5718.75rpm,,11.52ms,70.00,,,,,,,,,,,
2005-10-27 11:46:19,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.70V,,,,100.00%,,,5781.25rpm,,11.52ms,71.00,,,,,,,,,,,
2005-10-27 11:46:19,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.80V,,,,100.00%,,,5812.50rpm,,11.52ms,71.00,,,,,,,,,,,
2005-10-27 11:46:19,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.76V,,,,100.00%,,,5843.75rpm,,11.52ms,71.00,,,,,,,,,,,
2005-10-27 11:46:19,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.80V,,,,100.00%,,,5875.00rpm,,11.52ms,72.00,,,,,,,,,,,
2005-10-27 11:46:20,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.80V,,,,100.00%,,,5875.00rpm,,11.26ms,70.00,,,,,,,,,,,
2005-10-27 11:46:20,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.76V,,,,100.00%,,,5906.25rpm,,11.26ms,71.00,,,,,,,,,,,
2005-10-27 11:46:20,,,35.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.84V,,,,100.00%,,,5875.00rpm,,11.26ms,70.00,,,,,,,,,,,
2005-10-27 11:46:20,,,35.00º,76.00ºC,81.12%,87.36%,91.26%,,,0.86V,,,,100.00%,,,5906.25rpm,,11.26ms,71.00,,,,,,,,,,,
2005-10-27 11:46:20,,,36.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.80V,,,,100.00%,,,5937.50rpm,,11.26ms,71.00,,,,,,,,,,,
2005-10-27 11:46:21,,,36.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.88V,,,,100.00%,,,5937.50rpm,,11.01ms,69.00,,,,,,,,,,,
2005-10-27 11:46:21,,,36.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.88V,,,,100.00%,,,6000.00rpm,,11.26ms,72.00,,,,,,,,,,,
2005-10-27 11:46:21,,,36.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.88V,,,,100.00%,,,6000.00rpm,,11.01ms,70.00,,,,,,,,,,,
2005-10-27 11:46:21,,,36.00º,75.00ºC,81.12%,87.36%,91.26%,,,0.82V,,,,100.00%,,,6031.25rpm,,11.01ms,70.00,,,,,,,,,,,
a log from 3k to redline 3rd gear middle day heat
