Korndogg
- 471
- Jun 21, 2003
randolph,
Vermont
hey guys
this is the damnest thing.. i'm at a complete loss and very confused. please help!
i just installed energy suspension motor mount inserts. get the car back together and go to start it, but i get nothing (just clicking.. from the starter i think?)
if i push start it, the car runs fine. took it for a drive and it pulls hard, as it should.
(i like the motor mount inserts, very nice. wheel hop gone). i noticed however that when i push the AC button the AC does not come on and neither does the indicator on the button. everything else appears to work properly.
i have checked all of the connections at the terminals a million times, and that's deffinitely not the problem.
FYI:
i did not remove the rear engine mount from the car.. i could not easily get it out from under the shifter cables and i did not want to remove the bracket from the engine. i was able to slip the inserts into the mount while it was loose yet still down in the car.
so, ALL that i did to install the inserts is remove the battery and tray, unbolt the mount, install the inserts re-bolt the mount and i was set (i also did the front mount by removing it, the front is simple as cake)
does anybody have ANY idea what could be going on here?
i cannot start the car unless i push it. i would replace the starter, but what's up with the AC problem? that makes me think that it isn't as simple as the starter...
please help
much appreciated
thanks guys
FYI:
please help
much appreciated
thanks guys
