Billsuperg
- Oct 31, 2005
Palm Bay,
Florida
95 Eclipse GS-T 1 mm over pistons, new rings, rods, crank and oil pump. Pressure regulator is clean. Oil is Mobile one 10W-30. Engine starts, appears to flow oil when cranked with the filter adapter off. But very low, not enough to turn the idiot light off oil pressure. Possibilities, machine shop put wrong bearings in, balance shaft bearings omitted or misinstalled, some other source of internal oil leak, or new oil pump is bad.When it first started it ran fine for 10 minuets or so until I gave it some throttle to back out of the drive way, then the idiot light turned on. Any help to narrow down this problem will be appreciated.
Thanks,
Bill
