Timing belt? AHHHH
97EclipseGSTer
60
Jul 27, 2005
New England, Alabama
Hey hows it going guys. Well, I finally got my 2G T-dsm back online. I had to take my turbo off, bore it out, bore out a evo3 o2 housing, put a tubo manifold on, change alot of gaskets, 3 inch exhaust system, Greddy Big fMIC, 255hp fuel pump, Greddy e-01...blah blah blah, at this point I think I'm just bragging. But! I was reading through the forums and someone mentioned about pushing down the center of the timing belt and if a cam turned/ moved while you did it then i'm sh*t out of luck. What does this mean? I pushed it and the intake cam (farthes one) turned so so very slightly, its just one of those things that just agrivated the crap out of you, i need to get this fixed....some phobia.
P.S. Is the timming belt supposed to be tight? I can push it down and actually slide it 1 cm left to right on the tooth of the cam. I put a greddy timing belt on and it has less than 2000 miles, I'm thinking they didnt put it in at all.
THANX DSMers! :dsm: :talon: :laser:
I have no idea what they are talking about. Do the timing marks line up? I can push on my belt a little, it changes frequently, sometimes its tight sometimes it loose. Sometimes I can move it up and down 1/2" probably?
OK man how long has the been running after sitting awhile the lifters will bleed down and give you slack thats where you get the clatter from it might just need to run awhile. give some more info it will make the diagnosis easier
  • For sale 4G63 Competition Clutch, Clutch Fork
    Competition Clutch, Clutch Fork $75 + shipping and PayPal feesYou must be registered to see...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
