timing problem
bstclum
56
Sep 18, 2005
spokane, Washington
:talon: :confused: my 1g talon has a greddy timing belt and everything is tight but it keeps skipping time. what could be wrong? how do i fix the problem? :talon:
is everything tight everywhere....You need to turn the engine over (by hand) at least 6 times and check that the belt is tight everywhere. Also make sure the auto tensioner is set up properly. If thats not the case make sure the all the pulleys are in good condition as well. A t-belt will not throw itself without a reason.
Follow this and you'll never go wrong.
