ECTurboDSM
- 109
- Sep 26, 2002
Cary,
North Carolina
Ok, my problems have gone through a few stages, so I'll start at the beginning. I was driving to school and my radio would die when I hit the brakes and eventually the car started to die when I stopped. I made it to school but when I went to leave, the car wouldn't turn over anymore. I went and got a new battery but I bought a different group size since they didn't have the one I needed and I needed it right then. It has the same CCAs and reserve capacity but I failed to notice that the terminals were reversed. You can guess what happened, I hooked it up backwards and lots of sparks. I flipped it around and got it home. The battery was still not recharging, so I had the alternator tested and it was bad. I put a new alternator in and still had problems. Things like the automatic seat belts and radio and the beeping when you turn the key weren't happening until the car was started. The radio (Alpine CDA 7892) was still dying when ever I hit the brake pedal. It happened even when I was sitting still in the driveway, and I checked the ground for the radio and it was a good ground. I replaced the 80A alternator fuse, and a good majority of the large fuses in the engine bay and also in the fuse panel in the driver side foot well. I did three consecutive starts tonight and by the fourth, it wouldn't start anymore. I pulled the battery and the alternator and had both tested and they both tested good. The alternator had a slight odor to it, so they replaced it (lifetime warranty, i wasn't going to complain). I just finished putting everything back in and the car started (as it should with a recharged battery) but the alternator light is on now. I am about to blow this car up, so anyone who could possibly save my sanity and the car, we would both appreciate your help. Thanks.
WTF
etc...
