billyfusco
- Dec 14, 2004
Winnipeg,
I just did a compression test and here are the results 180, 170, 150, 180. I did a wet test on #3 and got 190. Is this a big problem?? Could this cause idle problems? Should i rebuild???
Also i've been trying to track down my power loss and idle surge. Did a boost leak test 3 times a week for months. I replaced the injector o-rings/insulators. ISC, Biss o-ring, TB shaft seals. I'm almost holding 20 psi. But i can find anywhere else it would be leaking from???Could cylinder #3 be my slow leak?
