Clutch Problems
MaddMatt17
Aug 8, 2004
Lexington, Kentucky
A few months ago I replaced a Clutchmasters stage 2 with an exedy.. It has been a complete pain in the ***. I have never had so much trouble out of any manual in my life. Heres the problem, the clutch disengages really close to the floor, sticks everynow and then, always looses pressure, hard to get in gears, sometimes get stucks in gears, and so on. So far I have replaced the slave cylinder, master cylinder, and clutch lines. I just had it at a shop to replace shifter cables, it was so hard to change gears, the actual shifter came off the shifter assembly and twisted all my cables :thumb: . At the shop they adjusted the push rod, and it was feelin great, stiff , and smooth shifting... 2 weeks later i am back in the same boat. I bleed my clutch every other day. Seems to do.. ok for a bit then starts same ol bs.
Please help, it would be much appreciated!
I checked the rod and everything came out good, but I did find the problem. The master cylinder is going bad again, so i just goin to buy a rebuild kit probably. Thanks for the help though
