boost
superdaddy
38
Sep 16, 2004
Madison, Wisconsin
car wont boost pass 13psi in first gear but fine in other gears.......no matter how much i turn up the boost, boost will stay 13 in first gear but boost will go up in the other gears......
so what psi are you trying to hit, turbo type, ported or not, what boost you trying to hit? things like that can help us
im trying to boost around 20, but first gear is always 13 no matter how much i crank it up......... 2nd,3rd,4th, and 5th is usually around 20, but first is always 13.......... car is pretty much stock except for exhaust, modded maf, and boost gauge and controller......... any help would be helpful, thanks....
Have you upgraded your turbo? If not, then your turbo maxes out around 14lb in first gear.
this is the first time it has happened...... it usually boosted at around the same as the other gears........
