Omega
- 1,558
- 10
- Oct 10, 2002
Randolph,
New Jersey
There is another tread of mine with the whole issue here but this is specificly for the pump.
Where the pump inserts into the assembly; there is a cap, o-ring, and then a spacer. When I put the pump in, the spacer would wiggle around. I didn't think too much of it, but now I think that it could be the cause of the fuel pressure issue I am having. Should that spacer be seated firmly in the assembly? I think that the fuel from the pump is not making it to the supply line to the engine.
