hbaldwin
- May 29, 2003
After leak testing my 94 ES I discovered that there was a hole in the Condenser. I also see that there is a sticker on the inside of my hood that says that this is an R12 system. From what I understand R12 was phased out in 94 in favor of R134a. In doing this test I noticed that my car appeared to already be 'retrofitted' for 134a. I had it tested around 2 years ago and I think that they may have done this without informing me. The problem that I am having now is I purchased a new condenser 'R12' and neither fittings (accumulator/high side) bolt up. The threads are too big on the fittings...What should I do? What are the key differences between the R12 and the R134 condensers?
Thanks!
Thanks!
