Starting Problem
90PlymouthLaser
May 27, 2005
Tracy, California
Hi all,
I have a problem with my 90 Laser. It decided to start when it wants. I can start it when it is cold sometimes, after it warms for 2 minutes it is done. I looked in the manual and I looked for the start relay. The book says it is under the radio. So I dismantled it and found nothing.
Does anyone know where the relay is?
I’m hoping that that maybe the problem.
Any help would be cool as I have no other wheels and can’t afford to get it towed and shop labor.
Thanks
90Laser :(
It should be down by your ecu. I think close to the bottom corner of the ecu on the driver's side. Good luck!
Chris
my starter relay on my 91 laser is on my passenger side fire wall. check there not sure if they changed that rapid over a year LOL hope this helps.
