MindBlowin03
- 881
- 672
- Apr 11, 2002
Jessup,
Pennsylvania
The new Talon has a problem where I have no dash lights and no tail lights. Found out that the TAIL fuse under the hood has some control on that so I find out mine is blown. I replaced it twice and as soon as I flip the lights on(to see if the gauges light up) the fuse blows. I tried another dimmer switch with no success. I pulled out my CD player and rewired it(all fine), and then pulled out my gauges and rewired them(fine also). I also unplugged the dimmer switch completely and still a no-go. I do have brake lights in the rear so I assume that the rear wiring is good. Only thing I can think of now is to follow that wire where ever it is exposed and see what happens. I know its in a harness(which seems untouched) through the engine bay so Im going to assume its fine in there even. Any ideas on what I should do?
UPDATE:
After trying numerous things I finally did something really dumb and threw a 20a fuse in there. Everything worked for a few seconds, then I got some smoke under the dash and found the problem(I think). The clutch safety wire is toast. There is a green/black and a black. The black wire has no insulation at all and now I have to dig into the harness to find out how far is goes.
Does anyone know what this wire has to do with the tail fuse/illumination? Also, are there any shortcuts I can take, as in running a new wire from the plug to (?)?
UPDATE:
thanxs bro.
