ddavisaf
- 2,588
- 81
- Feb 12, 2005
Langley AFB,
Virginia
I searched. So don't yell
Anyway. Blew my stock turbo. Heard the turbine grinding against the compressor housing. Nice sound. Swapped it for a 14b. No shaft play what so ever. Turbo was good. Put the 14b on. No boost leaks. Turned the boost up to 14 psi. 10 miles later. I blew that turbo. It went from no shaft play to bottoming out of the housing just like the old one.
Oil: I bent the stock 2g oil line to where it was unuseable so I relocated the oil feed line to the 1g position off the head. There was a small leak from on top the turbo (14b) same line. Seemed like the brass washer was missing or something. So there was a *little* bit of an oil leak from the turbo oil feed line. Blades on both turbos are mint condition.
The car is parked right now in fear of me beating it with a baseball bat. I need a starting point troubleshooting wise. My friend told me he's heard that the balance shaft bearings might fall into the oil pan, causing the turbo to blow but that doesn't make any sense to me. I figure you would notice a missing bearing because of vibration. So I'm assuming it's oil related? I run Semi-Synthetic 5W40. 6 bucks a qt. Pretty good stuff. The turbo came off of a 1g running 10W40 non-synthetic (the second turbo, the 14b). Could that have possibly been the problem? No, I didn't prime the turbo because I took it off his car, and slapped it in mine the same day.
I've got a steel braided oil feed line to hook up to the oil filter housing, but I want to know if there is something else that is causing a bigger problem.
Sorry for the length.
Thanks,
Damien
Thanks,
Damien
