sjgYFZ200
- 1,107
- 3
- Jun 25, 2004
Albany,
New York
Well as some of you may know, I succesfully ran 30psi on a 14b with an all stock car. Well today/tonight I finally got it back together with another OEM headgasket and ARP studs. Understand, the HG blew into a coolant jacket, sending 30psi into my coolant system on its way out of the engine. This mangaged to blow my radiator. So all back together with a new radiator I start it up. Runs real good, idles good, pulls hard. Then I noticed the smoke. This smoke is so bad its like instant fog. When its Idiling, you cant even see the taillights. So I drove it down the street to the corner store and back. The wastegate is frozen, and I disconnected the MBC to be sure. I'm really thinking its the turbo because it wasnt made for that kind of boost, and it was full of coolant. I put a shopvac to it before I put the head back on, and from what I could see, I didnt see any more puddles. Let me sum it up again...white smoke, at every RPM
So much smoke it creates a fog that lingers, and makes cars dissapear behind me.
I forgot to add that I had the head machined and pressure tested.
