boost gragh what do you think?
Acezwild88
64
Jan 6, 2005
San jose, California
ok the gragh below is from my profect it is graghing the boost. the boost is set to 15 psi. as you can see in the pic below is i only go to 14 and drops to 13 which is more visable in second gear i didnt take the car up to redline and i think in first i hit a fuel cut. i know the pic isent that great but in sec when it levels out it is rough looking like a mt. its not a great pic but i am trying to figure out what is going on with my boost i did a vacume leak test and i fixed the ones i found i need some more help thank you
when i did the test the guage wasent staying up on the pressure i fiured it was just figured that the throttle body wasent trapping it in i didnt hear any other leaks though. so it didnt hold so do you think its still a leak so big that i just can't hear it? when it was pumping the pressure when up though and when i took it off there was some air that came out.
what i dont understand is why if i set my boost to 12 psi it gose up to 11 and drops to 10 then if it can hold 13 when i set the boost higher why cant it hold 10?
Honestly, I don't know.
But if you have a boost leak why try to figure out the strange behaviour when fixing it should help.
The throttle body isn't going to trap air in the intake during a pressure test. Air flows through the FIAV and BISS and around the slightly open butterfly just like it does when the car idles.
That's why it's important to make sure the engine isn't stopped at the small window of overlap when both the intake and exhaust valves are open in a cylinder. The pressure test checks the entire air path including any cylinders that might have their intake valves open.
Steve
thanx alot steve ill try the test again and if i cant figure it out ill just blow it up :thumb:
but it sounds like a vac leak to you?
We are talking about boost but from what you have described I'd bet you have some more intake leaks. I could be a bad vacuum line or just about anywhere else.
Good luck, it helps to have a friend help and use soapy water if you need to find the leaks.
Steve
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
