ozzeran
- 232
- Jun 21, 2004
Arlington,
Texas
Ok howdy all, I just recently installed a ported FP big28 brand new lastnight, I went ahead and installed a walbro 255lph HP pump as well. With the boost at 14-15psi it feels A LOT slower than my t25 did. I talked to several tuners and they told me that my big28 at 14 psi will be much more improved versus the t25 at same boost. I dont see any diff, just seems slower, no more kick in the pants. The install went well, no leaks, good idle vaccum readings. I am still using my unported factory 2g exh manifold and o2 housing though, but that shouldnt matter for this. I still have to put my injectors and wire the AFC up then tune it, but I was expecting a pretty good jump in power just popping the turbo on at 14psi. Should I be expecting this w/o a tune? Here are the following mods:
fp big28
Dave brode upper i/c pipe
1g bov
joe p mbc@14psi
kn with maf adapter plate
full 3inch turbo back exhaust w/o cat
this is on a 2g gst 5 speed.
thanks
fp big28
1g bov
joe p mbc@14psi
thanks
