kkskater
- Jan 3, 2005
Menomonie,
Wisconsin
After doing the shifter linkage mod with the bearings, I take my car out for a spin to see if there is a difference. Then I notice no boost! I was running 20 psi fine earlier and now it is at about -7 vac then goes to 0 when it is sapoossed to boost. I have no idea whats wrong. There is a hole in my exhaust manifold but it has been there before and nothing like this has happened. Also when I shut off the car around the battery area it sounds like something is bubbling like its boiling. I just replaced the optima battery so I hope its not that again. How do I check if my turbo is blown? I dont think it could be that though because it was boosting fine about a hour before this happened. This car is really starting to piss me off, just bought it a week or two ago and have already had more problems then every previous car ive had combined
. Any suggestions on what could be the problem? Thanks, Kyle
Look at my mods list to get a idea what kind of turbo system im running if that helps
. Any suggestions on what could be the problem? Thanks, KyleLook at my mods list to get a idea what kind of turbo system im running if that helps
