Possible brake problem
12sec92Tsi
187
2
Jul 20, 2004
Hagerstown, Maryland
Hey guys I just had 2 new axles and ball joints installed on my 92 fwd and ever since i got it back i have a squealing noise like metal rubbing metal which is fairly loud, especially at slow speeds. the car did sit for like 2 months prior to being fixed so maybe that caused something to go bad. I searched and have narrowed it down to either brake pads or rotors or wheel bearings. I will do the bearing test tomorrow but im leaning toward pads or rotors. What do you guys thinks. any help is greatly appreciated. thanks in advance. :talon:
check your brakes...........be sure too, if you replace em, that you put anti seize on the bolts when you reinstall everything, this will help ensure that your calipers move in as the pads wear down...........hotwheels of turborides
Thanks for the input, ill be sure to do that because it looks like ill be doing the brakes soon. :thumb:
