gstowner
- 246
- 1
- Nov 13, 2004
Creston,
Iowa
I got home tonight got out and heard a spewing. Opened the hood its leaking from the bottom passenger side. Right around the bottom hose. I checked the hose it looks ok. But for the amount that it dumped I dont know if it could be a worn hose. It dumped most all of it. I was at my uncles house and I ran in to pick up my broter. Then he wanted me to fix something on his computer. I completely forgot the car was running. When I went back out the fans were on. Does anyone know if there is something wrong or its just a case of it got too hot? thanks
Also there is a small hose under the housing sorta that seems to split very easy. It seems to be one of those, that gets over looked when checking the hoses.
We tried to look under the car and it didn't appear to be coming from a hose. Our mechanic stopped up to take a real quick peek. He "thinks" it might be coming from the resevoir tank, but can't be sure until it's torn down a little. Hopefully that is all it is.
