SilverJester
- 95
- 1
- Aug 31, 2002
Has anyone ever put a 95 turbo engine into an 97 (also turbo)? I am having problems with the car not starting (no spark), I pretty sure it's not the coil pack or anything like that because it was working fine before. The car still has a 95 ecu (runing dsmlink). The only thing I can think is that there is something different in the wiring harness going to the CAS. because when I installed it the connector for the CAS was different (although still made of three wires red, blue, and black) but I had to cut the connector off and solder on a 95 style CAS plug onto the harness. I mathced up the colors (blue with blue, etc.) but my question is....Could mitsu have changed the wire colors in a 95 talon (TSi Awd) and a 97 GSX...this would cause the CAS not to work thus no spark??? Or what else could be my problem?
