boostyGST
- 325
- 1
- Aug 11, 2004
Flintstone,
Maryland
Ok.....followed vfaq directions to bypass the o2 sensor exactly.........my o2 sensor did not come on the first time I started the car and did not come on the first 10 min it was running. I then turned the car off and let sit for approx 10 min, started iut again and I popped a cel, because i do not have a datalogger, i cannot scan it and clear it.
Look at www.vfaq.com/mods/O2bypass.html
This is what I did I took the 1Mohm resistor, soldered to the blue wire and soldered on end of it to the 1 micro-farad capacitor. Then i soldered the other end of the capicitor to the white wire. From there I took the two black wires soldered them to quick dicsonnects and soldered both of them to the ends of the 12ohm resistor.
Shrink rapped then pluged back into the ECU side of the harness.
What did I do wrong? Was I supposed to follow the way the diagram shows on the second diagram on vfaq? What else could be the prob?
Who else has done this? Was there any probs when you did it?
PLEASE HELP ASAP!!!!!!!!!
thks
thks
