Major oil leak and only 5psi max
90gs-turbo
70
Dec 1, 2004
colo,springs, Colorado
Well friday I went to change the manifold gasket and I found out that the guy who had the car actually put on a 1.8liter manifold gasket on...I put the 2.0 turbo mani gasket..I dont have an exhaust leak no more but for some reason I can only boost to 5-7 psi max on sunpro aftermarket boost guage hooked up right..I have checked for a boost leak and didnt find one :confused: :confused: ..Then I had to get some new spark wires cause 1 had been cut I was driving the car for awhile then came home lifted up the hood and noticed part of the valve cover right where the plugs go was flooded in oil..I though when I put oil in I forgot to tighten the cap..So I cleaned it up tightend the cap drove the car for a couple more hours then popped the hood and there was a lot of oil on the valve cover agian so I checked the oil cap it was closed all the way..I noticed there was a trail of oil running under the oil cap though :confused: Im completly lost on both these problems :confused: :confused: :| :dsm:
you probably need a new oil cap gasket, or you could have over tightend your valve cover bolts and cracked the valve cover.
I was thinking a oil cap gasket because every time it happens there is a trail of oil under the oil cap and running down the oil cap..Thanx :thumb: :dsm:
