my95tsi
- 926
- Dec 6, 2002
Chicago,
Illinois
Ok well this just started to happen recently and i can't figure it out. My idle gets really low somtimes especially when the car is reved up then put into neutral. About one out of ten times the car dies. It seemsto get worse when the lights are on but it's hard to tell. The car runs just fine for the first 10 minutes when it start it up then it gets really low. Most of the time it will justidle at below 600 and almost die but it won't. It's not until high revs when it just drops all the way. My voltage at night with the lights on when my foot is on the brake is at 11.6. Driving it is at 13.2-13.6 on average. I had my alternator tested by autozone and it's just fine. It has alittle lower amps that average but it's still good. My belt also likes to squeel at startup. I replaced all belts over a year ago and the alternator belt is tight as can be. I'm thinking it might be something else other than the alternator.
