Fluid Everywhere!!!
Jetblack
149
Apr 5, 2003
Baton Rouge, Louisiana
My clutch pedal lost pressure last night and went to the floor. I was able to build up a little pressure back in it but not enough to put the clutch in gear. When I looked under the car, tranny fluid was pouring out and power steering fluid was empty. It's not leaking from the brass plug but from in between xfer case and tranny housing, could this be covered under the xfer case recall and could this have any thing to do with the clutch pressure because when I pumped the pedal the fluid came out faster?
