under 2k RPM lose 2 cylinders
sleeper2g
30
Feb 7, 2004
Lakewood, Washington
I got a 6 bolt with a 2g head but under 2k rpm I lose 2 cylinders above that every thing is fine the 6 bolt is a jdm from 89 to 93. Please help quick
its not a misfire issue its cylinder loss I know it will throw the code b/c of the sensor splice .
Obviously you didn't read up because you would know that the RM can cause the ECU to go into limp mode and shut down cylinders to protect itself.
Thead moved.
