12sec_91gsx
- May 8, 2004
san francisco,
California
i have a 1991 gsx, with a han full of mods, you've probably seen me up here a couple days ago, about piston rings, but now i need some help on rebuilding my engine. i think all i needed was piston rings, but since they have to rip it open, might as well just replce the old stuff. so i found a re ring kit, which includes all gaskets, main and rod bearing, and piston rings, and thrust washers if applicable. now i just want to replace the piston and piston ring with je or wiesco buit i cant find a site to look for it. i also need to find the lowest price for these performance piston and rings.(dont have a lot of mioney) if someone can give me some insight, on this,or if they have a better solution in solving this problem.
thanks steve
ps:i push black and a lil blu smoke and just a lil bit of white smoke out my ass. when i really push the throttle down and start boostin. i only boost 9lbs. and i mean u can see the smoke its bluish/ black and a lil whit afetr i let of the pedal.
thanks steve
