boost test...results
1993TalonTsiAWD
339
6
Jan 26, 2003
Glendale Heights, Illinois
I finally did a boost test. I hear a Very loud hissing sound around the turbo outlet, but can't feel anything, the gasket looks shot however and I'm going to replace it, Also the dip stick hissis a lot, but it still on pretty tight. I have a problem with my boost guage. It'a a auto meter, and it has got off zero somehow. It stays at 4psi for 0 now, don't know how to recalibrate it, or should I start the engine up and see if it resets itself, It has been sitting for a year not being used. Also not sure why cylinder #1 is lean and the others are fine, replaced the cylinder #1 with a new injector, but that really didn't help.
One more thing where can I find the turbo outlet gasket, it's what they call the j-pipe
And the boost guage does move up and down, but stops at 4psi I had the system tested at about 15psi.
any help will help LOL
thanks Derek
Is it bad if the dip stick hissis or is that normal, someone thinks if the crank case has pressure then a valve seal, or rings are bad please tell me this is not true and how to recalibrate my boost guage
thanks Derek
There is no way to recalibrate your mechanical boost gauge.. at least that is the case with my VDO.
As for the pressure test.. having sat for a year without oil circulation.. the rings/valve seals are likely dry. Get the thing running and do a compression test and then pressure test the intake again to see if ok.
BTW.. the plastic FAIV valve assembly which plugs into the thermostat housing tends to crack causing a boost leak. That may be what you hear around the turbine outlet.
Autometer boost gauges are pretty easy to set back to zero. Take out the bulb then get a pen/screw driver/allen wrench and push the big metal ring either in or out. Sounds weird, but it should make sense once you take a look.
I did this to mine when it sat at 1psi and now it works great.
I have ran the engine since then and compression is 155-160. Why is the crank case being pressurized too, is this bad, the dip stick will blow off at around 18psi and the valve cover leaks a little air too. I hope it's nothing major. On a side note I got everything back together and it ran like crap,, I flipped out and got very mad. Come to find out the spark plug wires aren't staying on, Is there a trick to getting them to stay on, or should I return them and get a brand name, there carquest brand and were 50bux
It runs good as long as the spark plugs wires stay on LOL I think that may be the hole problem at top end. I need a fix of some sort. Plus vac is 17 or 18at idle. I haven't boosted it yet until the plug wire problem is fixed, I replaced the PCV valve to cure crankcase pressure problem, but it still does it, It runs fine though, Is there a line I left connected that should be connected I put the tester right were the intake attaches to the turbo, and pumped it to 15-18psi, also my coolent sensor has a wire that is bare, could this mess anything up I asume it would, but I can't just keep guessing because I'm running out of money
thanks Derek
What is FAIV valve. I have the same leak around the outlet area as well, already did the oulet gasket twice. Thanks.
It's FIAV. Fast Idle Air Valve. It's on the bottom of your throttle body where coolant lines are running. It keeps your idle high when you first start the car for a "warm startup".
Sounds a little far from the turbo oulet but I'll check tomorrow. Thanks.
    • 92AWDHX40
    • eclipsemf
