fastwaytech
- 85
- Apr 26, 2003
Seattle,
Washington
A couple of days ago, my crank pulley seperated on the way home from work. It was at really low speed. I heard some weird noises, even some noises through the exhaust, almost like something came loose under the car, in the rear. I mean in addition to the noice near the engine area (clanging). And all of my dashlight went on, you know, alternatro and what not. But it was still running, so I figured it wasn't the timing belt breaking.
I pulled over immediately (actually had to drive to a nearby parking lot, but less then a 1/4 mile, maybe an eigth of a mile, about a half a block), and it was still running, popped the hood. Noticed that accesory belts were not turning. And yea, I looked down to see the crank pulley had seperated. I turned off the car and had it towed.
Well the next day I started the car, and noticed that it idles at 2000, and if I give it gas, it doesn't really want to rev very easily at all. So I figure that my timing belt skipped or something. I turn off the car, and when I turn it off it kind of makes a "clank" sound.
Based on this description, for those of you with experience with a timing belt slipping, skipping, or whatever, how bad off do you think I am?
