lerxst
- Oct 30, 2004
TC,
Michigan
I must admit I'm now officially bitter. Here's the scenario:
Since I got my 1990 Talon Tsi AWD, the Tach never worked. Except ONCE. It was really rainy, and it started fluttering, worked solidly for a bit, then stopped. That was over 2 years ago.
Since then, My theory is that water was shorting the empty plug where the Tach Noise Filter is/was supposed to be, since after reading a lot of FAQ and diagrams, I've noticed it missing.
Here's what I've done in the last week:
Cut the Tacho Noise Filter connector and twisted all three wires together bypassing the filter altogether. Soldered, Heat shrunk, Taped, replaced. I like solid connections and weather sealing.
Removed the coil pack, verified that all wires from the coils and to the Tacho Interface are good. Applied terminal grease when refitting the wires after cleaning the terminals. Did the same with the 4pin output connector.
No go.
Removed the coil pack again, and ran a complete new set of 4 wires from the first coil, second coil, ground, and interface output. Cut the wiring harness on the car and put a brand new "very nice" 4 pin connector on the harness, and it's mate to the 4 brand new wires I ran from the coil pack.
Car runs, but still no tacho.
So, What are my options at this point? Should I start looking at the Tacho Interface? Is there a way to test it? Should I start looking behind the instrument cluster? Are there ways of looking for the Tacho signal there, or perhaps a way to simulate a Tacho Interface pulse to verify that the gauge works?
I'm stumped and grumpy...
-jre
No go.
-jre
