zerok318
- 139
- Mar 5, 2003
OK, I just got my car back from a really well known shop that deals with DSM's. I had an o2 housing completely custom made for my 38mm external wastegate. after I brought it back home i notice a small leak at the top of where the o2 hooks up the the new wastegate. I thought nothing of it untill days later i notice pieces of the metal gasket sticking out and almost cut me. I was able to move the wastegate (it was loose). So instead of taking it back to the shop, which is 2 hours away from where i live, i decided to eat the cost and do it myself. its been a bi***. i had to pull the turbo/o2housing/wastegate all off at the same time to get to what i need pull off the gaskets. My question is did it only blow cuz it not tighten properly or could it have been cuz i was running rich and then when i was tunning it with dsm link slightly had it running a little lean at idle? the first pic is the gasket to the input part of the wastgate and the second one is to the release (dumptube)
