kchaazz
- 1,166
- 80
- Oct 2, 2002
PENSACOLA,
Florida
hello there. im just wondering what would cause me to get 15psi in 1st gear all the way up to the redline, then get a spike to 13-12 psi and level off at 10psi through all the other gears? i did a boost leak test and got none in the ic pipes, but perhaps there is a leak in the tb area cause i do get a high whisle when hitting boost while driving? do i need to put my engine at tdc then hold the gas pedal down while doing the boost leak test in order to find a leak in the tb? and in any case, how could this cause me to get full boost in 1st and less in the other gears?
by the way, perfect compression all the way across- 160psi, no smoke ever, and car still has loads of power all the way- but more in 1st.
please help me out here, this sucks.
