johnk
- 402
- 3
- Jan 29, 2003
Worcester,
Massachusetts
I have no problems starting my car or driving it but the ride had become rough. So I hooked in my data logger to try and figure out which cylinder was causing all the havoc. I ran through the injector test and found #2 came out not affecting the idle. I checked the spark and the one comeing off the #2 plug was a lot weaker than the rest so I replaced the wires and the plugs since it had fouled badly. Still to no avail. I looked to fuel next. I checked the impendence all 4 injectors came out with 3.2 - 3.3 ohms. Checked for voltage from the harness. I have a digital so the meter reading was erratic but still registering some current then not and back and forth so I assumed it was getting a pulse. I tried taking the harness from 3 and putting it on 2 the idle didn't change from that either. With spark and fuel checked far as I know I'm not sure where to look or what else to double check for spark and fuel. The fuel and ignition are completly stock except the magnacore wires.
