dsm dominator
- 47
- Jul 18, 2004
guelph,
so i have found the lil bastatrd that is draining my battery, its my MPI relay, is it possible just to hook the power wire (pin 8 or sumthing) to a switch so i can just cut the power whenever i turn off my car?
also how can i tell if its the relay itself that is the problem,(ie short, or bad relay) of if it is infact a bad ecu?
o and i have searched the forums, i could get as far as pinpointing were the drain is
