HESITATION ABOVE 4800, gas smell inside
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
Hi. My car hesitates above 4,800, and i can smell gas when i am inside the car... but not outside... maybe fuel pump? any ideas? maybe it's unrelated.. looking for local store that i can buy boost leak supplies from
Hesitation is usually spark plugs or plug wires and the gas smell... is it only whn you come to a stop? I would think that is the sign of a bad o2 sensor.
I would just take a look at the fuel pump, I wouldn't know anything about that so maybe someone else could help...
dude you are making multiple posts about your car. You already said in another post that you think you have a boost leak and already brought up your engine codes. How about fixing that first before asking other questions. Your boost leak might be causing all these other issues your having.
