1.8laser90
- 336
- 3
- Jun 8, 2003
alliance,
Ohio
hey,
i have a 92 awd 2.0 turbo with 152,000 miles.. since i bought it it has made a puff or 2 of blue smoke only on start up and somtimes not at all. the car has sat for a year before i bought it because it needed a ecu. well after doing alot of work to it (water pump, timiming belt, ecu....) i hoocked the the turbo back up and have driven it maybe 3 times but stopped driving it cause my gauge was reading 14 pounds of boost which i guess is reallly hi. so i stopped driving but it it has bin started and moved around the driveway but since yesterday i started it up and took it down the driveway and back it started smokin REALLY bad.. i thought it caught on fire! but no it was coming out of the exhaust, so i discounected the turbo and its still the same... it smokes up the hole nieghbor hood i mean i've never seen a car smoke so bad! at first it was blue but now its like a blueish white and just poors out. the thing seems to run ok i guess it doesn't really miss, and it revs fine but somtimes the engine gets really shacky... i'm going to go check the spark plugs and see if there fauled or covered in oil, coolant w/e... if anybody has any ideas please speek up! thanks alot Cory
it runs pretty good now and desn't smoke anymore thanks alot fasteclipse... what i don't get tho is how could the thing even start or run like it did with like no compression?? thanks alot, Cory
