Popup headlights have a mind of their own.
pinknuggit
530
Oct 15, 2003
joplin, Missouri
Ok.
When i got my car, the popups did not work. I researched and found out that the big relay in the fusebox that controls them was missing. I went to the junkyard and got a new one.
Now.
Whenever they are down and I turn the lights on, they still stay down. I have to move the light switch from on to off really quick about 4 times, and then the popups will come up. The only thing is that when i turn the lights off, they will stay up. They will not come down at all. I have to manually crank them down. Whenever i disconnect the battery, they will both rise as soon as i connect the battery again, and you guessed it, will not come down.
I checked the motors, and when i send voltage to them, they spin awesome. They feel smooth.
The problem i'm having is that the motor's aren't getting any signal to work when i turn the headlights on. The motors themselves are good. I can pop the hood and reach in the window and turn the headlight switch, but all i hear is a clicking coming from the relay box (normal). Like i said earlier, i have to turn the switch about 4-5 times real quick before the big popup relay clicks and the lights come up.
No, it's Not a mechanical problem, it's an Electrical problem. My assemblies and motors all move like Butter, but i'm not getting any Voltage to the motors.
"When i got my car, the popups did not work. I researched and found out that the big relay in the fusebox that controls them was missing. I went to the junkyard and got a new one"
It may be posibble that you simply have a "bad new juckyard part". You should get a brand new relay if you can and go from there.
