damentor
- 81
- Feb 24, 2003
Milwaukee,
Wisconsin
Hello,
If anyone can offer some advice/comments regarding the following please do.
I have read that on the 1990's the shifter cables were both adjustable from inside the car by the shifter assembly, is this infact true? Because the Mitsubishi dealership insisted they gave me the correct cables, I even had them give me two different cables and none of them have the double adjustments on them. So I decided to measure from the mounting/bracket points from the stock cables that were originally on the car(the double adjustable ones) and the two sets mitsubishi gave me.
One set of the Mitsubishi cables was upto spec atleast it appears that way. I then put them on and now it grinds mostly going into 3rd and sometimes into 4th (I can get around it grinding at all if i very gently put it into 3rd or 4th. I still get a little click sound when I get into them when it doesn't grind. I have tried adjusting by the chilton, by what people have said online, also with trial and error. Still does it for some reason. By the way I am running syncromesh in there.
SUMMARY:
1990 Talon Tsi Awd 5-speed, syncromesh.
Won't shift into 3rd(grinds alittle/clicks) or 4th(clicks) unless I gently put her in. (Shifter asembly loose? or something worn/loose?)
1990's must have the double adjustable cables? Dealership still sell those?
syncro's going? anyway to test specifically?
P.s. - Sorry for making 2 threads about it just trying to get some feedback, mods can delete one or whatever works.
SUMMARY:
