dnsyang
- 58
- Jul 31, 2002
Chicago,
Illinois
HELP.....I'm stuck!!...This is for the both fronts of my 97 GSX...I can't get the wheel bearing assembly off the axle....is there any other bolts besides, the 4 that are on the back? Do I need take the whole axle out? Is there a pin by the rear where the CV boot mates up to the rear on the hub...I need help fast!!! Here are some pic's I took....
Heres the front pic of the wheel bearing hub...(as you can see, I soaked it in PB Blaster)...
Heres the new wheel bearing hub assembly...
Here are the pictures of the 4 bolts from the back...
HELP!!!!
HELP!!!!
